1 - 20 of 45 Posts
I'm about to take the dive on a nitrous kit and spray bar and I wanted to see what everyone was running as far as front/rear sprockets go. My previous setup was -1,+3 with a 190 Shenko but I think I want to go more aggressive this time.
Bike will be primarily raced at the local 1/8th mile with the occasional trip to the 1/4 and will see some roll on street action against some high hp cars from time to time.
will -1,+6 be too much?
I think I'm gonna go -1 and +8 on my 08, which is 16/49. I'll have it out about 5" and be used for primarily my local 1/8th mile, but will be able to run 1/4. I may have to go to the stock front sprocket depending on how large a shot I eventually put on it.
wow yall are crazy!!!! you dont need that much gear guys..... depending on how much you weigh and what is done to your bike makes a big deal on the gearing not to mention how big of a shot your using !!!
*Extendmy10r your going to waste your money on a spray bar setup !!!! They dont work that great unless your using a wet system and to be honest we have made more power with single foggers then the spray bars have!!!!
The Blue 10 that runs out of are shop has a single fogger and it makes 180hp plus !!!! and yea its a street bike!!!!
Discussion Starter · #4 ·
Enlighten us then man! I'm here to hear other's experience. Here's my setup:
195 lb rider
06 10R
Roaring Toyz Slip on
BMC Race Filter
Stretched/Lowered (gonna call you about the swingarm)
Wet Nitrous kit with GSXR1300 spray bar (ordering this week actually)
PCIII
Butterflies removed.
I'm looking into a ported head and cams potentially but plan on keeping the stop bottom end and spraying a 40 shot. Gimme some input!
I'm 300lbs in boxers hence the gearing. Not to mention it will be a long time, if ever, before it sees nitrous.
I agree though, spray bars are junk.
195 lb rider
06 10R
BMC Race Filter
PCIII
sounds like your on the right path we will talk more when you call
well if your going to run on motor then you would be fine with that gearing
i just pulled my motor so i dont mind telling my setup..here we go,keep in mind im 190 suited
11 over stock
penske double clicker
spyder nitrous=40 shot
stock motor
billet basket
air shifter
akra evo II ti
bmc filter
pump gas
pc III
bolt ons galore...u get my point
i run 2- 2+ for nitrous and was running in the 5.5x's in the 1/8 and my motor gear was 3- 4+ and was running in the 5.7x's and nobody could touch this bike in my area.like flea said the weight and setup are key..i could ride my boys 1000 and go a tenth faster just cause of weight.u need a good map also.i run the mini nos controller and it works flawlessly every fuckin time.going fast isnt cheap either if u wana run with the big boys u gota spend the $$$$$$$$$:thumbsup:
11 over stock
stock motor
billet basket
air shifter
akra evo II ti
bmc filter
pump gas
pc III
yea money makes speed !!!!!!
^^No Bike Bum^^
i will be in the market soon after Xmas for a noz setup myself... im wanting to spray abit more than a 40 shot, probably 80 or 100... i know that motor will have to be prepped for it... if it would ever just get cold so i can stop riding!!!!
Big exhaust cam , and a set of rods !!!
hahaha I'm 11 over with a penske shock and mine...stands straight up on a 50 shot!you better be about 14 over unless you wana do a back flip...
^^No Bike Bum^^
lol.... scary ride huh??? im between 12" & 13" at the moment... im gonna start off with a low shot and work up... if i feel 50 or 60 is all it can handle ill stop before i get uncomfortable and not want to use it... but im still gonna try and build the motor to hold as much as possible...
JEEZ
i feel you on that weighing more than most as im 270lbs....stupid thanksgiving ahahaha but thats crtazy!
Nos Controller guys !!! We spray over 100hp on street bikes guys.....its all in the setup !!!
^^No Bike Bum^^
i wont argue if you show us the way :thumbsup:
Bring it to the shop and we will hook you up and you will never have to worry about anything except trying to figure out how to carry a extra bottle with you :thumbsup:
1 - 20 of 45 Posts
