1 - 9 of 9 Posts
Would it be a upgrade to fit some Nissin Capilers off the ZX-14 on my 08???? I know The brakes are pretty good as they sit now but i want a little more braking power.
I have a set of Nissin calipers, braided brake lines and better fluid setting in my garage, I will probably put them on next weekend. Stock are good but Nissin, lines and better fluid are alot better in my book.
I've got 310mm discs from a ZX14, the same size as gen 3, and I've tried ZX14 Nissins and 08 Gen 3 Tokicos. The Nissins are much stronger, I had oem pads in both sets, and I felt they were a bit too much for the road on my Gen 2.
I think you'll need spacers if you use the Nissins, I'm pretty sure the Tokicos have an extra 5mm-ish built into the caliper.
1 - 9 of 9 Posts
