1 - 11 of 11 Posts
I used to race brackets in a car years ago, but never tried any of my bikes at the track until this past month. First time out I took it easy and got a feel for track. It's an old 1/8 mile track with a short shut down area (less than an 1/8).
I wanted to ride the bike in and race it with absolutely no changes to see what the base capabilities of the bike were. No stretch, no strap, no tire pressure changes (30psi on Q2's) and no burnout. I'm -1 up front, but have no other performance mods.
Today was the second try at the strip and I decided to get into it a bit and I've hit a wall in terms of progress. Basically, the top end feels good and I'm bumping the rev limiter in second before the traps (110?). 6.90s. The 60 foot times, however, suck. 1.8's and launching anywhere above 8000rpm gets me wheelspin off the light. Below that and she's bogging out.
So....my questions for the gurus are: Is this the point where I need to start doing burnouts, dropping rear tire pressure.......or do I just suck on the clutch? (or all of the above) And.....which would you recommend I work on first?
And.....yeah, I know I need seat-time. I'm going to get that, but I would like to be systematic and avoid making some bad habits.
Thanks in advance.
Certified SLOW
You should try doing a short burnout just to clean all the crap off the tire. At stock length with the Q2 I never had problems with traction unless I had caked up VHT on the tire and didn't burn it off.
What are your 330 times? With 1.8 60ft you should be doing better than 6.9s. You also have a pretty low trap speed, what is the altitude at your track?
ps - Less than 1/8 mi cut off? That sucks man, I love my 1/2 mi cutoff... especially since I only run 1 front caliper and no rear brakes!
Altitude is relatively low. Maybe 2000 feet. Temps were in the low 90's today.
I couldn't tell you the 330 or what the actual trap speed is. The track only gives the 60ft time and ET. What rpm does the limiter come on? I can probably figure out the mph from that.
x2 on doing a burnout. also do you have the frontend strap on the bike ? if not i highly suggest you gettin one, helps keeping the front end down and i wouldnt worry about tire pressure bc your swb and you want need to mess with the rear tire pressure untill you stretch the wb of the bike.
Banned
get a first gen clutch, btw you did good, I ran all stock 7.21 at 113mph, going back with a strap, lowered and geared this time
What do you weigh? I ran 6.7s just lowered and -1 even stock muffler, I sucked with the clutch back then. I'm only 145lbs tho, I would suggest lowering your bike and adding some gear!
I'm 180lbs in gear. I don't want to drop the forks or the rear. I will however, consider strapping and doing a burnout.
Looking at these:
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=2744208
Can I get away with longer caliper bolts or do I NEED to get this:
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4781528
..or this:
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=4801175&showprevnext=1
I figure I'll go with drag pack from cycle concepts when this clutch is toast (yeah, I do read the old posts)
What's the smoothest way to come out of the waterbox? I assume I'll back in, hold the front brake, spool her up to about 8000rpm and get her warm. Do you just lighten up on the brake and back off the throttle and let it climb out of the water?
You guys are great, keep the advice coming.
Certified SLOW
Do NOT do your burnout in the water. Hop the rear in the water and move forward out of the water and then do your burnout.
Is this so I don't paint the undertail with water? School me.
The water will keep the tire from building heat and will get in the grooves in the tread pattern, then when you leave it like you still sitting in the water. Also drive around the waterbox avoid getting the front tire wet if possible, it can hold water as well.
1 - 11 of 11 Posts
