1 - 20 of 40 Posts
i see the braided line...but whats other differences are there in the "next gen"?? and @ what will the cost be??
Easier to install and you can place the solenoid directly into the spraybar. Many Gen ZX10 owners have problems finding a place to put the solenoid.
Discussion Starter #14
What are the advantages of the braided line over the nylon tubing??
In my opinion it is just personal preference. Th poly lines that I supply with my other kits are have a spec of 750 psi. Some Nitrous kits poly lines have a spec well below that.
Discussion Starter #20
Forgot to say jet placement will also determine if you can run poly lines are steel braided. If the jets are after the lines then you should run steel braided. If the jet is before the lines then you can run poly lines. Nitrous jets also reduce pressure to allow this.
1 - 20 of 40 Posts
