Just purchased a 2016 zx10r less than a month ago and currently have around 240 miles on it. I am having one issue of concern that I will have to get the dealer involved with, but would like to know if anyone else is seeing the same thing.
The bike has shut down on me around 8 times so far, out of the blue and for no reason while underway. I hit the starter button and it fires right back up. No alarms or codes. It's like someone hit the kill switch. I am sure it will not have any active codes to easily troubleshoot and it doesn’t happen consistently.
It shuts down whenever I am going up to the next gear. I am usually around 5,000 rpm and switch to the next gear. I pull the clutch in and put it in the next gear and if I just hold the clutch in, rpm comes back down to below idle and the engine shuts down. So, if I pull the clutch in between gears and apply zero throttle it will shut off. As long as I switch gears and keep applying some throttle it will continue running. It runs great with no issues and if I use the quick shift I have no problems. I know it will be hard to troubleshoot since it isn’t happening every time. I am sure I can capture what is going on with my go pro camera. Let me know if anyone has had this issue or knows what will resolve it. Thanks
