221 - 233 of 233 Posts
Discussion Starter #221 (Edited)
I'll just leave this here.....
12psi on a 96 degree day.... a little wobbly with the boost control still, as it's ramping with mph (that's about 150-something in third)... but good enough to go to bonneville and play without the fairing on. :)
Discussion Starter #225
is that the lightley ported head with the cnc valve job? stk valve springs?
Yessir. It's a touch too rich up top for the fuel I'm using (and it was heat soaked/hot as hell in the garage!), so that's not really helping either. I should have taken the time to do cams/degreeing, but I was just flat out of time & resources. But, that's only 12 psi.... that turbo can huff about 15 in there before I start to get nervous.... so there's that.
Not stock valve springs though... they are the APE offerings with stainless exhaust valves and the Ti retainers.
look elsewhere not the head with the valve seal and springs u have causing power drop at 12k. not even stk cams that are in time imo. that said what's wrong with making hp/torque like that at lower rpm. pretty good initial powercurve, that would work for me, and sprockets are cheap.
Discussion Starter #227
Hahah... you're right.... though it's a little hidden in that graph as boost is rising up just before that 10K mark after the controller gets a hold of it. While I'm sure more appropriate cams and/or cam timing would let it carry a bit better, the real culprit is likely (stupid) high charge heat and the turbo getting real close to it's practical limit... especially with an internal gate.
It's just a knee jerk reaction to blame the things I couldn't get to, I guess. :) But that torque from 8K up feels pretty good, no lie. If this thing had drag gearing it would be terrifying without a lot more wheelbase and a good shock.
Uhg... regretting the stock head & cams though right now... party is pretty much over at 12k.
You do realize that 99.99% of zx10r owners will never even get in the door for that kind a party in their lifetime no matter how many times their ecu will get flashed:crackup: That's a great power curve all under 12k.
I really wish I could have been there for these runs. Trying to balance out life responsibilities, obligations and recreation.
Discussion Starter #230
...heres an idea of the difference a little bit of intake temperature makes: same boost, just 10 to 20 degrees lower iat when starting the run.
The water injection was waaay too aggressive at about 12k and caused it to break up... threw a nitrous solenoid in the line and set the way up to pulse the flow down by about 50% after that.
Discussion Starter #232
First event got mostly rained out... they only did 3 days of racing on a really, really bad course. I didn't run the 10R at all... we just ran the Harleys. We did clock the fastest bike at the meet with a 198 and change on the APS bike, though... so there is that. :)
Next week I'll run the 10R without the fairing so long as we have a track that doesn't resemble wet snow at the 2 and the 3 mile. :(
Discussion Starter #233 (Edited)
...record qualifying pass and the backup run... barely squeeked in over the record. Salt was wet and loose... the second video sums it up perfectly. :) Wanted a lot more mph than I got, but that's all she would suffer that day. Not for a lack of trying though... the rear tire was turning at about 210 mph for the last 7000' of the return run. Fuuuuuuuhhhhglyyy.
