I'll let you know. I want to do just these calipers and pads first and see the difference it makes. Then I'll do pads, lines, master cylinder if I need too. Lines will be a must though since the original rubber lines are already over 15 years old.
It's going to be cold all week, with the exception of Friday, so I may take these to work Thursday with my front and rear stands and then ride in Friday and replace them Friday night at the shop
Right now initial bite doesn't happen until the lever is pulled in at least 50% of the way, and that's after bleeding them. I have the lever adjusted all the way out at it's furthest position right now and it's a reach for me to even grab it
I like the way you make progressive changes and measure/evaluate the effects of every bits.
Some people do not, but nothing is wrong either way.
Is your MC the radial or axial type?
Extreme initial bite I have experienced was on a Brembo system, which immediately stopped the bike while I was doing a slow U-turn, and I dropped the bike.
My Gen3 initial bite is sooner than your description, but the lever travel is more than desired. I am contemplating moving to 17mm or 18mm MC.
I just installed new Vesrah pads - they are about twice as thick as those old clunkers. Also received new (radial) mc so will have mc, braided lines, calipers, pads and DOT4 installed by the weekend.
New brakes require a bed in process (repeated stops from say 60 mph with cool down period between, but never come to a full stop) so I won't know about hard stop performance for awhile, but I'm sure it will be night and day
Initial bite on the stock brakes was non existent
Also adding Toby steering damper (as a precaution). The Ohlins steering damper on the Gen 2 is weak but you can ship it out to be rebuilt (new oil etc) for alot less than new
Yeah, the 'never come to a full stop' while bedding in new brake pads is very important.
we should plan for it, find a suitable time and place to get this done.
