1 - 20 of 27 Posts
Hi everyone, I just bought an 04 zx 10 off a friend and it sat for a few years and now the tank has a bunch of rust in it. When I got it I replaced the battery and tried to fire it up(before I noticed the rust in the tank). It didn't fire so I pulled the plugs and it had spark but the plugs were dry. Then I checked out the tank and pulled the fuel pump and it looked terrible. My plans for the bike are drag only so I'm looking to remove anything I can to lighten it up. It already has a 12 over Adams arm, power commander, air shifter, alien head exhaust, etc. I'm wanting to trade the exhaust for a sidewinder and find a grudge style tank for sale. I bought the bike off a friend that was a member here, jake_04_10...I think that was his user name.
It was just regular gas, I ended up getting a stock tank off eBay. It fired up and ran good with the new tank and fresh gas.
Here's an update, the only things I have done to the bike since it's been running is a drag pack clutch, fiberglass seat pan, Penske shock, and flat blacked the whole bike since the tank no longer matched. I was at the track tonight and only got two passes. The first pass was a 9.31 leaving at 6500 since I wasn't sure how the bike would react with the new shock, everything went smooth so the next pass I left at 7800 but slipped the clutch too long. The 60 ft has a whole lot of room for improvement but that will come with more passes, the bike has been a few tenths quicker.
What's the gearing and your weight? That mph is strong. Congrats on the new bike.
Discussion Starter #15
I'm a lightweight, 155 fully suited and the bike weighs around 390. It's geared -2 +3. Once I get some more passes on it and get the 60ft down it should run pretty good.
Thats awesome man makes me wanna pull some gear from my bike to see how it mph. I'm -2/+6 fastest I've been is a 1.44 60ft, 9.36 @ 145
  • Like
Reactions: Drag10
Damn magma that's some serious gearing. What's it top out at?
honestly not sure never tested with gps but speedo shows 154 with speedohealer
Discussion Starter #19
Another update: best 60ft since I've owned the bike, it only picked up .01 on the et but it was 20 degrees warmer than last time I posted slips. Removed the Penske shock and put the stock one back on cause I couldn't get it adjusted correctly, I'll eventually put it back on and figure it out. It's bouncing off the limiter in sixt gear before the traps so I'll drop a tooth in the rear so the new gearing will be -2 +2.
1 - 20 of 27 Posts
