I just picked up an 05 ZX10R, and it is such a beast! The only problems i face is the front right turn signal does not work, and the turn signal indicator does not work with the right side turn signals, which i am assuming is hot off the front signal.. And also the high beam indicator does not illuminate when the highbeams are on, though the highbeams do work.. Im wondering if i should tear the cluster apart and replace the bulb or if anyone else has gone through this before? Thanks!
