Did you have this issue at all with the stock exhaust?
Any updates on this issue? I just installed an Arrow Indy Race exhaust on my '21 ZX-10R and it exhibits those exact same issues you mentioned. Was thinking / hoping a tune would clear this up.Okay…new here and couldn’t find the exact issue so here goes. Just installed an Arrow Race 3/4…with baffle in it sounds mediocre at best. With baffle out it’s a monster with ear plugs required.
Here’s the issue…when I run baffle out it seems like it’s surging at low rpm’s when I pull the clutch in when I’m slowing down to stop. And it feels really unstable at slow speeds in first. As of it wants to stall out or as of it’s just choking for fuel. I know new exhaust without a tune runs lean…just want to make sure that’s the issue and it’s not something else. The surging only happens until I’m just about to stop and then it settles and stops which is weird. No idea why it doesn’t continue. If I’m sitting in traffic and just throttling a little to get moving it will start surging again until I almost come to a stop. Never stalls. It just surges between 1K-2K rpm’s…almost sounds like a heavy cam lope. I intend to flash but I’m just waiting for it to ship.
Thoughts?
Thanks
I never even tried the baffle. Does it sound that much different? I know without it, its very loud almost too loud but sounds tough. I'll try the baffle to see.The only thing that made it run correct was having the baffle in. It still smells of heavy fuel in the exhaust too. I think the only fix will be a ECU flash or furl tune which I will do at some point. Most likely the Brentuning flash as it’s made for an aftermarket exhaust and will most likely fix 99% of the issue. Runs very well with the baffle in. Which once you run it a few times you will be used to the sound which is still loud. I thought the baffle free ride was a little mind numbing without ear plugs. I like my music too much for that.
I was also thinking to do the Bren tune since its available now. Would love to know if its that alone will clear up the surging.
Same here...I live in CT so riding season is pretty much over...I like at least 55-60 minimum.I ride specifically with the baffle now. I like it. Still sounds amazing. Doesn’t rattle my brain.
I think the tune will clean it up to almost perfect. Just my thoughts. Once I get it, not sure when that will be as riding season is all but over for me, but I will report back.
You will see, all of a sudden your bike will run correctly again. No searching no weird surging on clutch pull upon slowing down. Just smooth operation as it should be. And it still sounds mean and pops when shifting. I love it.Same here...I live in CT so riding season is pretty much over...I like at least 55-60 minimum.
I plan to get the tuner and will also report back results. Probably try the baffle tomorrow...can't believe it has that much effect.
Wow...okay definitely gonna try it tomorrow.You will see, all of a sudden your bike will run correctly again. No searching no weird surging on clutch pull upon slowing down. Just smooth operation as it should be. And it still sounds mean and pops when shifting. I love it.
So I installed the baffle today and wha-la…no more surging when I come to a stop and very little to no pops and bangs. Still sounds really good too. Like you I’ll be riding with the baffle in until I tune the bike. Ran flawlessly and much smoother at low speed as well. The lowered decibel level to me was perfect.You will see, all of a sudden your bike will run correctly again. No searching no weird surging on clutch pull upon slowing down. Just smooth operation as it should be. And it still sounds mean and pops when shifting. I love it.
All that shows is that Graves cans are no better than standard and are a waste of money. The idea of an aftermarket exhaust is to de-restrict the bike and make more power, so you NEED to retune the bike when you fit a pipe as they flow better than the stock pipe and the bike will run lean unless you retune it. Contacting Arrow claiming it 'fails' because the exhaust they make flows better to make more power is laughable.Make certain that manufacturer built your can for our bike. If so, then send it back as the can fails. Let them know, in a conversational tone, if you're speaking with Arrow tech, clearly state exactly your problem.
If you send it back for a refund, then check graves cans. I've been running graves cans for yuks and 10'rs years and years with no need for tuning.
GreatI ride specifically with the baffle now. I like it. Still sounds amazing. Doesn’t rattle my brain.
I felt the same at low speeds … first gear just boggles but doesn’t die … can’t stay smooth at a low constant speed … possible flash might fix it … but I have the Arrow and I think that thing sound amazingOkay…new here and couldn’t find the exact issue so here goes. Just installed an Arrow Race 3/4…with baffle in it sounds mediocre at best. With baffle out it’s a monster with ear plugs required.
Thoughts?
I felt the same at low speeds … first gear just boggles but doesn’t die … can’t stay smooth at a low constant speed … possible flash might fix it … but I have the Arrow and I think that thingOkay…new here and couldn’t find the exact issue so here goes. Just installed an Arrow Race 3/4…with baffle in it sounds mediocre at best. With baffle out it’s a monster with ear plugs required.
Thoughts?
ih yes I know the feeling !!! 20 years riding only now I own my first liter bikeAll exhausts systems aren't created equally. When I owned multiple exhausts(M4/SC Project CRT/Akra) I could create the high/low surging as the OP described by simply fitting on the SC CRT slip on. My bike is flashed and tuned and I can make adjustments with my Woolich Tuner, and no matter what adjustments I made with the SC Project CRT fitted I experienced some degree of low/idle surging in first gear. I would then install the Akra Carbon Long can exhaust and the surging immediately disappeared with no adjustments made to the ECU. With the Akra fitted my bike idled as if I had the stock system installed. No surging and jerkiness in first while coming to a stop...completely smooth. I then installed the M4 and the surging was minimized but was still there, just not to the point where it seemed as though it would bog down when coming to a stop.
After performing this experiment I just came to the conclusion that not all exhausts are created equally as it relates to this behavior. The SC Project has a 70MM pipe/exit(lesser back pressure than the Akra) so I chalked it up to the larger the exhaust exit the greater the chance that I will have to deal with this behavior. It took me no time to learn how to utilize my clutch to minimize the issue when I had the SC Project CRT installed.
YMMV.
I don’t have the db on and it is crazy loud …. I have more of a 1 gear problem at low speeds .. can seem to open a little throw to smooth it out I need to get it to a higher rpm to smooth out the rideWith the Arrow Race 3/4 system the bike behaves completely different with the baffle vs without it. Without the baffle I get the idle surging coming to a stop and plenty of pops and bangs.
But just adding the baffle back in everything seems to run smoother and much less pops on decel. The surging completely disappears as well. Decibel level os reduced but no where near stock…just right imo. No baffle is quite loud but tolerable. I haven’t flashed the bike as of yet but that should only improve things.
For now this is far better than the stock can and I’ll do the Woolich flash once available.
