1 - 20 of 26 Posts
Still working with the clutch on this extra short (53") wheelbase. First few passes were crap ET wise, but this was the best pass of the night:
Dial-in: 10.00
RT: .385 (Not my best for the night)
I1: 1.766 (Not my best for the night)
I2: 4.400
I3: 6.549
MPH: 115.570
I4: 8.410
E.T.: 9.999
MPH: 139.212
Bests for the night: .202 RT; 1.706 60'
congrats on the new personal best killer :thumbsup: did you ever try out that 15t you got from me ?
Thanks zx racer. I haven't tried the 15t yet. I keep improving with the current setup, so I'm going to use it until I'm consistent with it and then change to the 15t. I'm at the top of 4th through the traps right now.
:+1: your bike is running good keep doing what your doing we can play around Sept. too at the track. :eek:ccasion1
Bloo
Bloo
I'm going to need alot of seat time to keep pace with you my friend. Maybe I need to lose 10 more pounds.
oh ok cool... seat time is the key man and wat gearing you runnin now ?
Not really I keep gaining pounds too many Tacos and :beer: :badteeth:
Your loss of weight you should be proud of your getting consistent now ....yeah other things to work on but your loss of the weight something I haven't done yet and your bike is running good to boot. :eek:ccasion1
Rick
Discussion Starter #8
Discussion Starter #10
  • Like
Reactions: madnessracing
Discussion Starter #12
I had 2 - 9.94 passes last night. I have pics of the slips, but there seems to be a problem with the site and uploading them. Remember, I'm 230 lbs. suited on a 53" wheelbase.
Bloo
1killer called me last night at the track I can tell he was as exited as me when I got my first 2 9s runs in one day it's an awesome feeling :wink:
1killer is already there with me maybe better when he gets the launch down(edit meaning reaction time down..sorry)..hint hint :wink: in the next month or 2 at the track with 2 heavy guys it should add up to some good racing. :cool:
bloo
Have I just found my rival??? We seem to have pretty much the same setup and running pretty close times. Great job, man! That gives me motivation and hope! What are your mods?
Discussion Starter #16 (Edited)
ZG dark smoke double bubble windscreen
04 Spark Black center upper
04 Spark Black plastic between the rider seat and cowl
04 Spark Black cowl
04 Spark Black tail light cover
Custom airbrushed jack-o-lantern
Pazzo Black/gold levers
6k DDM HIDs
CA integrated tail light
Muzzy's flush front signals
Schnitz Racing front end strap kit lowered 1" through the triple trees
Fully adjustable lowering links as low as the swingarm will allow
Billet adjustable kickstand
Blue Gipro w/ATRE on soft setting
Speedohealer
Modified ram air tubes
BMC street filter
Factory Pro velocity stacks
Removed smog equipment
Sealed airbox
Intake screen removed
Secondary throttle butterflies removed
Low friction wheel bearings
Arata Ti full system with matte black shorty can and exhaust hanger
Degreed stock cams
Thin head gasket
PCIII with custom map
DJ quickshifter
Multi-function hub w/ switch
Ivan's block off plates
Scorpio SR-i500 alarm
Kawasaki/Ohlins steering damper kit
APE manual cam chain tensioner
06 front rotors and calipers
06 rear caliper
EBC HH brake pads
Galfer ss braided brake lines front and rear
Attack rearsets
16/41 vortex sprockets
D.I.D. X-ring chain
08 swingarm
Discussion Starter #17
bloo
Are you coming out tomorrow?
1killer, what kind of modification did you do to your ram air tubes? And did you notice any difference when you removed the secondary butterflies?
Discussion Starter #20
1 - 20 of 26 Posts
