1 - 2 of 2 Posts
a little background info: its an 04 zx10-r, 65xx miles on it. It has set all winter. i put a new battery in it and fresh gas and it started straight up. changed fluids etc ran great.
the problem: it started acting weird like the gauges would come on but dim even with the key off and it wouldnt load the injectors. when i try to start it the f.i. light will flash. i un-hooked the battery put it in and it fired right up like normal.
i parked it for a few days came back the battery was dead hooked it up to jump start it and the gauges were on dim. fi light on. the gauges will go off if i turn the engine off button(red one) to off but it sounds like there is an electrical whining from that lil exhaust servo..
i know its rambling and hard to understand but if anyone has any ideas where to start or has had the same thing happen please help me..
Thanks
Late Apex
Thanks
loose engine ground . bad starter solonoid
1 - 2 of 2 Posts
