Long story short. I was replacing the brake pads and discovered that my 06' ZX10R has 08 calipers, rotors and forks. Also I learned that this happened because of a front collision, so obviously the forks were replaced (KYB shinny new ones).
Looking further, I noticed that one of the stops of the tree clamp was broken allowing the steering to go beyond the max point. So since most of the front end is from an 08 I bought a 08 tree clamp to replace it. Now the problem is that when I was installing it I found out that the stem is longer.
Does anybody know if there's a way to replace just the stem from one clamp to the other? I don't know how to remove it. :headshake
Any help will be greatly appreciated.
