1 - 10 of 10 Posts
Do u adjust ur throttle play near the grip or remove the tank an adjust near the throttle bodies?
the adjustement i used was on the cable as it goes underneath the bodywork on the RH side and it crosses over the top of the Rad.
BD, did u have to remove any body parts & any tools involved?
I didn't do either as its a plastic knurled fitting with a plastic lock nut you loosen, adjust slack as you wish , then retighten.
MIA Post Whore
The one under the airbox is the return cable. Adjust both for best results. (my shade tree mechanic opinion)
Hey, I'm a shade tree mechanic too!
Just take the tank off. It's not really that hard at all. Then you can adjust the pull
and the push cables. That's really the only way to do it right. I fucked around adjusting the one you can see and could never completly get rid of the slop.
I'm too friggin lazy to take the tank off, just adjusting the one on top has worked for me so far.But doing both is the right way.
neither is wrong and either is right so there. :badteeth:
1 - 10 of 10 Posts
