1 - 9 of 9 Posts
Any one know where to buy just an actuator for secondary plates i really dont want to buy an whole throttle body assembly
I think you keep buying sh*t not related. In the manual it says if your TPS is bad it can't be replaced as it's adjusted from factory against the TBs..hate to say it but you may need a new Throttle body Asmbly not an actuator. Hope I am wrong but you are just buying stuff without knowing what is wrong f'sho like the ECU :badteeth:
Discussion Starter · #8 ·
its not coding the sensor is bad it is coding the actuator, i manually opened the secondaries and the bike ran past 7,000 rpm. The main problem is the secondaries are not opening at all. so the motor is starving for air past 7,000 rpm. Might as well try an 15 dollar fix instead of spending 150 for a throttle assembly.
1 - 9 of 9 Posts
