1 - 3 of 3 Posts
Ok so started doing an oil and plug change, also going to do air filter and remove 2nd butterflies. Looks like the gasket on the water pump is leaking alittle too, so i'm going to remove the pump for inspection. Just wondering if there is anything else I should do while I got it that far down? Only thing the bike has now is a slip-on, no PC so please keep that in mind. Thanks guys!
It was suggested to me by a member here, when I had the airbox off, to do the smog mod. The search button is where I found details on this. If you should consider a pcIII, now would be a good time as the wiring harness' are exposed -- or you'll be pulling off the airbox then too. GL.
Discussion Starter · #3 ·
no budget for PC for right now as bad as i want one. I am tune freak though so I'm sure one is in the near future
1 - 3 of 3 Posts
