1 - 6 of 6 Posts
I have a 06 ZX10R. Only has about 8000 miles on it. Tonight when I started it up to go to bike night, the "FI" light came on. It seems to be running ok, but I pulled it back in the garage and parked it so I don't cause any damage.
Has anybody else had this problem? How do you retrieve the trouble codes? I can diagnose car issues all day long, but bikes are new to me.
Any help would be greatly appreciated.
Discussion Starter #2
Forgot to add. It has a Two Brothers exhaust and a PCIII. It has not been professionally tuned, I'm just running a downloaded map. I always run premium fuel, even if it doesn't need it.
Did you remove the motor valve thing in the exhaust. My 08 I had to do some wire thing to get rid of the light. Read the Power commander install book and this should help your bike lite thing.
The exhaust servo is still intact. I did notice that when I turned on the ignition, the servo does nothing and even after starting it, it still did nothing. I don't know if this is normal, but on my ZX6R trackbike, when I turn the ignition on the servo turns a little prior to starting the bike.
1 - 6 of 6 Posts
