1 - 3 of 3 Posts
Need to see what color wire i have to connect the throttle position sensor wire from nitrous into the harness of bike
Certified SLOW
Cant help you there, but if you have a PCIII you can tap into the silver wire on it for TPS. Hope that helps.
yea that did work thanks i saw that the silver lined up with the yellow and white wire from engine but i had a power commander and the wire harness was different colors so i wasnt sure but 2 that say silver is better then one
1 - 3 of 3 Posts
