1 - 15 of 15 Posts
as you who seen my build thread. i have started with nothing and have built this bike. only thing left is fix dent in tank and paint it,blinkers and rear tail for brake
i bought this bike laid down and i do not know the wiring for the rear tail light.
ok...
i have no pig tail off the rear tail. 3 poles inside so i put female wire clams on the end and mounted them onto the poles in the rear tail light.
i do not know the location of what they do. so i am thinking tail light +, - and then other is passive for the brake light.
i have a small black plug 2 wire with black/yellow and red with a speck on it.
i have 2 bigger grey plugs i think they are to blinkers.
then i have a stran that has 3 wires blue/grey,black/yellow,red/spec
here is a pic below.
please help. i need the brake lit up tonight.
what year is your bike.....you always need to state everything when asking for help...with that said my bike 04 looking at the pic starting from left(where the stamp on housing says 13.5V) to right on the rear taillight
1st terminal- connects to the RED wire with gray bars
Middle terminal -connects to the Blue wire with gray bars
3rd terminal connects to the BLK/YLW wire
bloo
forgot to add out of the 3 connectors the 1 that is different is the License plate light the other 2 are for rear blinkers.
bloo
Servo's Eliminatus ;)
I'll call you tomorrow when i can get free.
I will bring my volt meter and a spare tail light to see if that one you were
talking about is bad. If it is, I know where you can get it fixed.
1 - 15 of 15 Posts
