1 - 6 of 6 Posts
Supercharged Mod
I don't have it on hand, but the 4-digit numerical code, the first digit of which will always be "6", that is engraved into the bearing you already have in your wheel right now, will tell a bearing shop all they need to know as far as the dimensions are concerned.
Banned
This is for the FRONT wheel of 2006-2010
6005 = 25X47X12
25mm ID (axel)
47mm Outside Diameter
12mm wide
The FRONT wheel for 2004-2005 is a 6004 = 20X42X12
I am not going to try and explain the entire coding system, suffice it to say the last number of the bearing size multiplied by 5 = inside diameter or the size of the axel.
In this example the 08 uses a 6005 front wheel bearing. Thus 5 X 5= 25MM inside diamter or axel size.
In the case of the 04-05 (6004) 4 X 5 = 20MM inside diameter or axel size.
6005 = 25X47X12
25mm ID (axel)
12mm wide
Thank u much...!:cool:
1 - 6 of 6 Posts
