So I have a question for you all.
My 04 zx10r wont shift into 2nd gear at all only 1st and neutral so I checked my adjustment on my clutch and it was fine it wasn't slipping at full throttle and my oil wasn't low either. Weird ...
And then I noticed my neutral light doesn't come on anymore and it wont start in neutral with the kickstand down only up and my fi light flashes until I put the kickstand up so my kickstand sensor works for sure and I know it's not my clutch safety sensor either because I have it bypassed and could start it in gear without it pulled and my shift fork teeth are fine and the linkage is tight so the only thing I can think is the gear indicator sensor or neutral safety sensor or if it's the clutch itself? Please let me know
