1 - 13 of 13 Posts
Need help from some drag guys...
My local track is finally opening up next weekend so I'm tying up a few loose ends this week. I will be running my '08 at SWB lowered 3". I am running stock (17/41) gearing at the moment (as I did last year). My question is if I go to 16/39 which is almost identical, it will give me an extra .5" of wheelbase. Is .5" really worth the trouble of swapping gearing?
Not in my opp... but the longer you go the better get some extensions, and try 16-42. I have 07 with 7 in stretch 16-42 and weigh 230 suited and run low 10's trying to get to 9's but only 2nd year for me. Good luck with whatever you do.
Its just my street bike, so extensions are not an option as of yet. I have had it geared down it the past and it just never seemed to pull as hard as with close to stock gearing .
i dont think so. but thats just my opinion. why dont you get some extensions? i was getting consitent 6.6s with a decent 60' having a lot of trouble keepin her on the ground. got the extensions and a shinko, first run i got a 6.3, and keep droppin. i ride mine 9" stretched on the street, rides beautifully
check out psychobike.com
Not worth it at all. Coming from someone who went -1 to gain 3/8" of wheelbase - its not worth it.
I raced mine at SWB forever, put blocks on it and never looked back. Went from running consistent 7.1s to consistent 6.5s. I'm 290lbs in shorts.
I've got a set of blocks for an 08+ for sale in the marketplace right now. Comes with an extended brake like and truck billet caliper hanger. All you'd need is a chain.
i put nearlly 400 passes on my 10 last season and learned more then i could ever read on a forum!id just get out there on one setup and ride the balls off of it and get used to every aspect of the bike before i changed anything,and when you do ....change one thing at a time,that way you know what to adjust if you dont like what u did.dragracing is all about keeping your edge and focus.i went from being the slowest to the fastest in my area on a 1000 in a matter of weeks by observing other riders and the diff in their skill vs. mine and adjusting to my setup.a stock wheelbase or even stock motor is all about setup!!!keep all your slips so you can see where your changing up!are you running 1/8 or 1/4?
Discussion Starter #8
I am running 1/4, the track finally opens back up this weekend and they are calling for beutiful weather. So I should be able to pick up from where I left off last year and keep learning
This guy is crazy, Rides beautifully.... Im stretch 9 inches also and the thing rides like a semi, Compared to a stock wheelbase 10
^^No Bike Bum^^
Ill have to disagree. .. I'm out 12" and mine " rides" great... with the suspension set right the ride is beautiful. ..... just turns like a limo. ... lol
1 - 13 of 13 Posts
