1 - 8 of 8 Posts
I planned on trying out the suspension settings that the testers used during the testing this afternoon. I left my issue at work. Could someone post up the settings for me? Would be very much appreciated!
Thanks in advance.
it should be posted on there website, if you have access to a computer at the time you adjust it
· Accountant in training.
Front:
spring preload--6.5 lines showing
rebound damping--8 clicks out from full stiff
compression damping--4 clicks out from full stiff
ride height--6mm from top of fork cap to tripple tree
Rear:
spring preload--27mm thread showing
rebound damping--2.0 turns out from full stiff
high-speed compression damping--2.5 turns out from full stiff
low-speed compression damping--1.75 turns out from full stiff
Chris
It may also be on their website like gldnchildek9 said.
Front:
Rear:
Chris
What weight rider was this setup for?
1 - 8 of 8 Posts
