1 - 12 of 12 Posts
Well..
It is true!! No top end power is to be gained when switching from a slipon system to a full system. Bike made within .75 HP of each other on the top end. Big gain in the midrange from 5500-11000 RPMs, with a little gain from 11000-12000
GUHL reflashed ECU with 14000 Rev limiter, PCV mapping, secondaries pulled out. Bike is stretched almost 8".
I the prior thread, Brock's was the most accurate in their dyno graphs comparing a stock, slipon and full exhaust.
Grave's showed power gains everywhere, so I don't know the exact data behind their dyno pulls..
The BLUE line was last July 27, 2012, 90 degrees outside. Slipon system
The RED line is yesterday May 30, 2013, 87 degrees outside. Full System
I put up a copy of the barometic data also from last year and yesterday. Almost identical so very little difference in air. Look at the DATES.. not the file names, we didn't change the file names before I took the pictures.
So.. there it is!! :eek:ccasion1
And a youtube video....
  • Like
Reactions: Crazi
Thanks again for doing the comparison.
One of the better comparisons I've seen where you get the conditions as close as possible when comparing to the previous dyno run. Nicely done man :thumbsup:
is it me or is the air-fuel significantly less consistent with the full system (in terms of making direct comparison). Seems to me there may be more to be gained yet with the full system if the fueling were as stable as with the slip-on......
Discussion Starter #11
This maybe true and even the dyno guy said the full system was a lot more inconsistent to tune. We worked out the fueling abit more but it didn't show any significant hp gains.
Squid wannabe
Good stuff man, thanks for the post.
Rep sent
1 - 12 of 12 Posts
