1 - 8 of 8 Posts
Thanks for showing us them!!!Bike looks good:helmet:
For the tail, I would recommend some RTV...on the top of the taillight. Then wrap it with a non-residue-leaving tape nice and tight all around the end of the tail sucking the plastics and light tight together then leave it to set up overnight. I think you will prefer it to the tape.
Discussion Starter · #4 ·
Thanks for the tip.
I used the foam to fill up the gap that is between the light and the plastic cowl.
The light doesn't fit perfect into the tail section as you can see.
Is this RVT stuff a 2 part epoxy or something?
Thanks for the tip.
RTV= Room Temperature Vulcanizer (silocone)
For me at least, this has been the best solution thus far for my Sharkskinz with an aftermarket light. It's enough to drive ya nuts seeing it out of wack or not tight together.
  • Like
Reactions: PJD
and BTW, your bike looks good!
Discussion Starter · #7 ·
Ok thanks for the advise i'm gonna buy some of that stuff and give it a whirl :)
  • Like
Reactions: Sebastian1000
1 - 8 of 8 Posts
