hey guys. just got the zx10r ad already have a problem. it seems like i always have to have the handle bars turned right to go straight. so i took the all the plastics of to see whats bent. turns out one of the fork tubes is bent. check out the pics:
on the last pic if you look closely you can see that if you drew an imaginary line through the two red tops of the fork tubes --- the front wheel would not be perpendicular to that line. you can see that the front wheel is turned slightly left. i dont think there is anything wrong with the frame, atleast it doesnt look like it.
so what do you guys think? is it the forks? get new forks and be done with it? or maybe try to fix them?
i know there are some smart people here, so please help
EDIT: I measured the distances between the upper and lower triple trees on both sides and the distances are EXACTLY the same. ant the top tripple tree is flush with the tubes on both sides
