1 - 4 of 4 Posts
Formerly CLCRACINGAaron
Ok, no movement...guess i'll switch to SBK class and run this anyway.
  • Like
Reactions: TrackToyz
Discussion Starter · #2 ·
Weekend bump! I’m located in Georgia, USA in case anyone was confused by the “UK” in the title.
Discussion Starter · #4 ·
It's all about the ratio. Stock bikes have to compromise the link ratio for a passenger, something like this is designed for single rider only situations. The ratio is much closer to 1:1 and will transform a Gen4 from a wheelie monster to a corner carver. You will most likely need to change rear spring rate to use this correctly. On a Gen5 it's not a massive difference but it will still be better than stock. Edge grip is improved, wheelie is controlled via suspension much better and rear end traction confidence will go up.
1 - 4 of 4 Posts
