1 - 11 of 11 Posts
18 zx10r
I've been as carefull as I can will the MSS OEM bracket but now no matter how many times I treid to carefully fit it it, somewhow, it managed to strip my damn threads.
Wow man, I’m sorry to hear that. I’ve had good luck with the oil catch can/rectifier bracket.
18 zx10r
I guess Its good on the race kit versions but I tried every way to fit this one and, as carefull as was, It still didn't fit right.
I had similar issue with the bracket I think the holes are the correct size but after painting/coating proces the holes are to tight I just whent through them with a drll did not cut any material just paint and they fit.
18 zx10r
Anyone know what that thread hole is used for? Asking just in case I should helicoil or place a timesert there.
I was talking about the mss 3.5 schock linkage the suplied bolts would not go through the holes on one side without removing some paint the threads where fine though.
I als have to rectifier bracket from them and that did not fit well either but could be my fault because my radiator is slightly bend from crashing...
Good to know after I’ve already ordered one of the rectifier relocation brackets LOL.
chances are if your radiator is ok you will be just fine.
Also have mss clipons and looked at their throttle but chosen another brand because itseemed a bit to expensive to me.
2012 (Gen4) ZX-10R
I can’t tell what it is? Looks like headers I can see in your photo but having trouble orienting myself...
What’s the bracket for?
1 - 11 of 11 Posts
