1 - 7 of 7 Posts
Factory it's in the upper hole position. I'm 6'2"ft only ride street. I don't feel cramped but if there is additional room why not? Any pros and cons or feedback to people that have moved to the lower hole?
Sent from my XT1565 using Tapatalk
The Pace
no problem, you must have the g4, drop the rearsets to the bottom. Thank God for the g4. You will have 'ZERO GROUND CLEARANCE PROBLEM;' assuming you have boot toes on the rearsets; and on even a cracked throttle in super tricky tight turns.
On the street you wont have issues with going to the bottom. I have mine set on the bottom on my gen 4 for street and then move them to the top at the track since I kept grinding the peg on the ground in the middle of a turn.
1 - 7 of 7 Posts
