1 - 5 of 5 Posts
MIA Post Whore
I moved my pc to under the plastic just behind the seat. The buttons are still accessable by only removing the seat. The sensor that was there has been relocated to outside the rail secured with zip ties. the PC is secured with double sided tape and two zip ties (just for extra security during hard landed wheelies).
A PCIIIusb will fit behind the right side cover below the seat. Remove one bolt, remove the cover and you have access to the PCIII. No more poblems with the PCIII taking up the limited trunk space on the ZX10R.
OG Post Whore
it'll be dope if you can transmit it over the satelite or something
good spot wstaab.....never even thought of that area....looks alot easier to access....only its a little more exposed...i might try that and glue some foam to the inside of the plastic side panel to further compress and pad it.
1 - 5 of 5 Posts
