Hello everyone,
It seems I have a mouse in the house that's been chewing on some wires within my gen 2… specifically the wires that lead to the sub throttle valve assembly
The little critter chewed off one of the wires very close to the actuator and I'm not sure if I'll be able To solder it back together.
So here's my dilemma;
From what I understand I have to replace the entire throttle body Because the sub throttle valve assembly is not available as a separate part
Can someone kindly tell me if it's beneficial in any way to go with a newer model throttle body…
My understanding is these actuators can fail and I don't want to keep purchasing throttle bodies only to essentially have the same problem.
I've read a few of the post where you can eliminate the sub throttle valve assembly… But that's not really an option for me because I've been trained to respect and work within the engineers design.
A couple of last thought… I have not removed the throttle bodies as of yet I have followed the instructions via the service manual But…I can't seem to budge throttle body unit…
Lastly, anyone have any tips or tricks concerning replacing the thermostat
Thanks again for your advice and consideration.
Regards,
F-18
Regards,
F-18
