1 - 6 of 6 Posts
for those of you that have done it, how in the world do you get the rear bolt off? the one located near the rearset. i've used breaker bar, air tools, electric impact equal to 150psi.
is there a proper write up somewhere for engine pulls?
thanx in advance
There are two parts to it. One part centers the motor and then the other part that is a longggg bolt that goes to a nut on the other side. You have to pull the long bolt out first then loosen the one that centers the motor
yea I pulled the long one out. the one I am trying to get out is about 1/2 to 3/4 length of the long one that has a nut on the other side. I cant get that beast to break loose. a buddy suggested torching but I just dont know about torching the frame around the bolt
:+1: clockwise (bolt it in) to go inside and release the motor?
1 - 6 of 6 Posts
