1 - 4 of 4 Posts
Clutch Basket shattered and a piece got wedged between the clutch basket and the crank causing a bent tooth/crank gear. Installed a new clutch basket after cleaning out the engine and the way it interfaces witht he crank causes a knocking noise. Deciding to part out the motor. Number 530.925.6863
Good Engine Parts
Complete head w/ cams and Ivan Smog Block off plates - 300
Complete clutch basket with clutch and friction plates (bought new - barely used) - 100
Stator - 50
Starter - 200
Transmission - 150
ASK ABOUT ANY OTHER PART OR ENGINE COMPONENT I'll verify that I have it and if it's in good working condition.
FYI: I called the listed number, and the OP has informed me this motor is a Gen 3.
1 - 4 of 4 Posts
