1 - 16 of 16 Posts
I have a 2008 ZX-10R and would like to get the steering damper modified.
Does anyone know where to send the stock steering damper to get modified to race specs? Or best way to fix the stock steering damper?
Discussion Starter · #6 ·
where is Dan's Service and what does he do exactly to the steering damper?
Dont mess wit White Ninja
I re-built mine and used a hydraulic fluid/heavier oil then stock and when its all the way open its like nothing is there, but when its all the way closed its as stiff as wood..Same feel as any gpr or scotts
Guilty by association
i know dan replaces the plunger and pin too making the whole set up correct instead of just uping the viscosity of the oil. but if the oil alone does the trick without messing anything up then that seems like a good mod.
Dan Kyle is a member here. Search for his threads....he goes into detail about what he does.
NOT TO SOUND LIKE AN ASS: Going this route will cost you $97....buying a GPR or Scotts will cost much much more. I've had this for over a year now and love it. It works great on the track and on the twisty back roads.
Try it before some other people convince you to use heavy motor oil or buy a $4-500 damper. :wink:
MIA Post Whore
I've not had an isse with mine street or track. Have yet to figure out what the "problem" is? When I want stiffer, two more clicks, want less, reverse it. :dontknow:
I see both sides of this. I've never had a problem with headshake on my room-mate's 07 zx10, even considering the uneven pavement we ride on. However, on my 04 the scotts has made a HUGE difference. If I had a 2nd or 3rd gen and felt the need for a better damper I would send the stocker off to Dan Kyle. I contacted him through the forum - his website is kyleracing.com (I believe) - when I paid for my buddy's damper to get rebuilt as a wedding present.
1 - 16 of 16 Posts
