1 - 13 of 13 Posts
Ok so today i was out riding the bike, was sitting in traffic, bike was running great, i stalled it. I got it started again and noticed it sounded horrible, like a 250, and i could tell there was something wrong. I pulled over i turned the bike off, and tried to start it... nothing.. I checked power at my pc3 and was good to go. I went home got my trailer and towed the bike home. I then unplugged the pc3 and hooked the bike out with out it.. bike fired up but still had the same miss sound. I checked temp on all cylinders and the #1 cylinder was 300+ degrees less than the rest. I was wondering if anyone had any ideas before i go as far as pulling the plugs tomorrow.
Sounds like no spark to me. I know it doesnt help much, but youre starting where I would. Plug, stick coil and the connections.
yep, i know there is no spark there, i just am hoping its nothing bad.. i would be pissed, i guess now is time to upgrade plugs, what does everyone use?
BigCat for Prez!
BigCat for Prez!
stock plug is NGKCR9EIA and check the coil packs to see one isnt bad.
Discussion Starter #10
well #1 and # 2 coils ohm out the same, they are ok, now time to pull the plugs.. ughhh then if nothing, i will be opening the valve cover..
Discussion Starter #11
well pulled plugs, not sure if this is a good thing or bad thing, but they all look fine, went ahead and ordered some ngk plugs i am gonna put in after work
Discussion Starter #12
well i got a update, noticed i was only checking the primary winding on the coil pack, not the 2nd winding. found the 2nd windings open on the #1 cylinder= bad coil pack, time to get a new one
The Pace
That coil. If all the plugs are fouled, then the top flies are not opening, which is the throttle servo motor fail.
1 - 13 of 13 Posts
