1 - 2 of 2 Posts
Mini Nos Hookup wiring....tps and tach signal??
Need some help...tps i think is the yellow wire on main throttle position sensor and i can either get a tach signal off the gauge or a negative coil wire. Ive read that some folks cant get a tach signal off wire goin into the gauge cluster, so is better to get one off one of the coils? If so which one and which color wire?? They all have a red wire and a black stripped wire...which is the negative. Lastly...no clue where to tap into the gear position sensor for the pcv ....any help is greatly appreciated.
Gen2 Ripper
I have called Holleys tech support and they can pull up your wiring diagram for COIL wire and tps. I use a pc3 with my nos mini dual stage + multihub. Also more people on psychobike.com run nitrous on 10's with that controller than on here so post over there too.
You will love that progressive controller man. I take out more and more ramp up every couple of months. When I get a real long arm, ramp up is going away.
1 - 2 of 2 Posts
