1 - 11 of 11 Posts
Speed Freak
MEGACYCLE RACE camshafts int. & exh. 04-09 ZX-10r
Hey guys, got a set of Megacycle cams that were in abike with maybe 50-60 passes on them.....
I know its hard to get in touch with megacycle but if you are able to I have the grind numbers on them
***EDIT*** THESE WILL FIT 04-09 ZX-10r's
Intake = 426x3B
01-07
Exhaust = 426x1B
03-05
Stock intake lift .354"
Megacycle lift .380"
Stock exhaust lift .331"
Megacycle lift .347"
These cams were about $900 new for the set and you should at least run better intake valve springs for the higher lift they have. I have a set of springs here as well stock springs are 200lbs @ 1" lift and these are 230lbs @ 1" lift
PM me or email me at [email protected]
Price for cams is $500 shipped
Postwhore with an 04
How does the inake cam compare to the kawi race intake cam?
Speed Freak
this intake cam is larger in lift then a race intake, as for duration I dont have a exact number.
Would I have clearanc issues with a .45 HG?
Sent you a PM
1 - 11 of 11 Posts
