1 - 20 of 26 Posts
But I cannot get the air box off of my 08.. WTF??
inappropriate
rotate and pull
The rear will come up, but the front will not budge.. Do I need to remove the fuel rail and such?
There should be a how to LOL!
I've got the tank off, and took off the seven or eight phillips, but the stupid top cover will not come off?
No sir, it will not come off.. Its like there is still something holding it on but I have looked and looked and looked but there is nothing else holding it. The rear of the cover will raise up but the front will not budge. I tried prying it open with a flat head and got it up just a little but it felt like it was going to snap so I just rolled it in the garage and said screw it for the night lol.
moving to "Performance" section
Gone Ridin'
Did you remember the screw in the center (at the bottom of the hole)?
All you need to do are remove the phillips (there are 9).
Discussion Starter #12
I just went back out there, and I honestly cannot find one in the center hole..?
I got 8 bolts around the top edge
Bad angle but best I got 07 ZX10r
:::EDIT::: I am the retard just notice you have an 08 lol not sure if teh above pic would help
Yeap, you have to take all of those out then open the air box and you will see more around the velocity stacks inside of the air box. Take all of those out and it will come right out.
Discussion Starter #15
Well I got the cover off, but how do I actually get the rest of the box off? I cant get to the side butterflies.
Discussion Starter #16
Anyone?
Discussion Starter #19
No, I got the cover off, but now I need to be able to get the rest of the box off so I can get to the side screws to where you cannot get the screw driver because it hits the velocity stacks?
1 - 20 of 26 Posts
