1 - 7 of 7 Posts
Hello guys !!
I have a ZX10R 08 with stock engine, Akrapovic exhaust, K&N Filter and of course the complete kit Ecu.
My dealer and I have no experience in setting the TC, the timing for the Quickshifter and the a few other little parameters that I have forget.
Can anyone post me a mapping ?
Of course I need to make my own settings for the injection and the ignition :mrgreen:
Thanks !!
Licensed Dist of HaterAde
Maybe if you'd introduced yourself in the "welcome newbies" section first...then they'd help ya out? LoL!!! (kinda like dropping in to say hello first) J/K man, I have a Gen 1 or i'd try to help you out...i'm sure someone will come along cause there are more than a few members on here with boatloads of info and experience. and hey....welcome to the forum!!!!!
What info do you have so far? Are the fuel and timing maps completely blank? Post up exactly what you have and we can go from there
Oh Sorry guys, i'm in so much forums, I forgot to do it (I 'll do it latter,i'm at work)
The map is completly clear, it's a completly new Ecu
thanks for the help
Newfie Bullet
I dont know squat about the kit ecu but is it worth it for a street bike or are you raceing it..If im correct you will gain alot from gettin a thinner head gasket which raises your compression ratio..Other than that,i know squat..I have seen some of the stuff in a buddys ecu on his r6,man what a ton of possibilitys ya have in there too..
Well I have read the FI calibration manual and I have a lot of questions
1.Compensations for acceleration: What value should I introduce ?
2-3 Map for injection1-2: Ok no problem, normaly haha
4 Map for ignition : We'll see if I need to change something
5 Map for Subthrottle : I have realy no idea how it works, if anyone can explain me the gain that I could have with it? I think it's better to close it a little bit during the acceleration, but i'm not sure .
6 Map for Top_Main Injection Rate : No idea at all
7 Pit rev limiter : I'll use the original settings
8 Auto Shifter Ingnition Cut: I'll use a PC3 Quickshifter, is 70 ms a good setting ?
9 Rev Spike control Sensitivity : No Idea to, I'll use it for my rain setup (and it rains a lot in Belgium)
10 Rev Spike Ignition Retard level : No Idea to
If someone can help me, that would be very nice ;-)
1 - 7 of 7 Posts
