1 - 20 of 50 Posts
After a long winter of redoing the setup we are finally making some headway with this thing. with only 600 psi of bottle pressure slipping through the clutch on generic ass settings @ 62.5" I was able to qualify the #8 spot with an 8.52
I got some good information from a guy to cure the clutch issue that has been plaguing me from day 1 and have somthing up my sleve to regulate the nitrous pressure to about 950 where it needs to be. also going to change the gearing a lil bit and get my wheelbase closer to the 63" it is allowed.
here are a couple pics from the weekend as well as a video from eliminations
http://www.facebook.com/?ref=logo#!/video/video.php?v=378218374514&ref=mf
Nice job. I hope you get that thing figured out this year. I was keepin an eye out for ya when I was watchin dragbikelive. Way to represent with the lone 10 :thumbsup:
What u running a 3mill kit in it ? Get with HTP Performance and they can tell you how to set the clutch up on it where it will hold....
Good job and i see things are moving along and I know this will sound crazy but gsxr 1000 valve springs will help that cluthch and would love to see come out to a few of the mirock races ,some good guys with some good info
Discussion Starter #13
that is EXACTLY the clutch info I got at the last race. I found a set and am gonna be putting those in asap. along with getting it tuned for f18 XXX fuel, and bigger injecters :wink:
Discussion Starter #16
Careful with changing the injectors. If I remember correctly you aren't allowed to change them
they changed that rule last year. the busa guys were bitching. Might as well do it to say on the safe side a/f wise cause im just about out of injector on spray right now and with the new fuel we gotta increse flow by allmost 30%
You guys running a bottle heater? I don't know what that does for you with weight but in the car business you pretty much have to on bigger shops to try to help with pressure drop.
Discussion Starter #20
we heat it with a torch to get it to around 1100 psi, but after sitting in staging it drops down a little bit and as soon as I purge it it drops to 600 psi. I have yet to see anyone do this but im gonna try this system. www.nanonitrous.com
1 - 20 of 50 Posts
