So I know I have seen a post about this but I can't find it again. I read a post about integrating the signals into the headlights.
:hello: Here is what I did:
-I cut the signal wire close the the signal on the mirror.
-Then I cut the running light by the clip
-I wired the running light and the turn signal light together
-Plugged in the LED bulb I bought
:dontknow: Problem:
-Due to the LED it won't flash
I know I could just buy a regular bulb that would work, but I think that the integrated needs to be bright since it is next to the headlight... any ideas on how to make this LED work...
I have done LED's in the back so yes I already have a electronic relay put in, so it isn't that.
btw... 09 zx10
