1 - 7 of 7 Posts
I was riding around tonight with my quiet insert and I think it may be causing me to lose power. It doesn't seem like the front end will pick up even in the slightest now.
Has anyone else experienced this?
I run without it but have rode with it and the front end picks up just fine around 6000 in first. If you have your TC on it may be the problem, mine won't lift with TC on.
TC was off and I was in full power. I'm gonna pull it out and just see what happens. Hopefully it's not the symptom of a bigger issue.
Thanks for your input.
I would think you'd see a loss in power if any with it out but I could be wrong. If you like wheelies though, -1 +2 will make you a wheelie machine.
I'm just using wheelies as a point of reference. I just took the insert out and rolled on the throttle. Came up no problem. Looks like the baffle holds power back pretty good.
1 - 7 of 7 Posts
