1 - 7 of 7 Posts
hey guys just wondering what everybody does to lower fork in trees ?? from what i can see i cant lower that much more with forks,maybe 1 inch or so (because of taper on forks ) is there someway to get around the taper ??? thanks
Don't worry bout that, just lower it where you want and tighten bolts. :thumbsup:
I've got mine pushed 1.5" through and had no problems with them tightening up:thumbsup:
thanks kenny ill try it this weekend
Bump...
had the same question with my 08. I haven't seen 06-07 forks up close...I'm guessing it's the same? The clipons will still be tight enough with the tapered part?
1 - 7 of 7 Posts
