1 - 20 of 25 Posts
My bike has a very slight hesitation at really low RPM's like below 2000 RPM at full throttle and it is effecting my launches do you think I need to add fuel or Take it away on my PC + or - or what ????? any advice greatly appreciated
Launch higher then 2000rpm? Adjust it +/-1 at a time and see what helps. This is the best way to fix the problem on your own.
you launchin for a drag race or just from a light. if you are draggin then i dont see why you would wanna leave at less that 2000 the bike makes no power. even when i take off regularly from a light i keep it above 2g on the tach
Hillbillie Mod
ok 2K rpm's is practically idle.
unless youre havin problems at say...5K or above, I woundn't even think twice about it personally. :dontknow:
adding fuel may bog it down even more?
launch from 6k.... not 2k....
Banned
i would be willing to bet your club president knows something about it.
^^ :crackup:
Discussion Starter #12
I should have made myself more clear... if I am cruisin around at say 30 and want to got WOT it hesitates before it goes for just a split second it boggs then like a rocket it is gone if I am going any faster than that it doesnt really hesitate
Discussion Starter #13
Oh yeah I dont remember doing it when it was stock
never rode in them rpm ranges so couldnt tell ya,but keepin it gangsta ,people are gonna clown you over this one because nobody rides a zx10 at those rpms,so all i could tell you is "DOWNSHIFT"
I know what you're tlaking about and I believe that's just the nature of the beast.... it doesn't have anything under 4k rpm
If you did anything to it, i.e. exhaust, velocity stacks, etc., then it will be too rich. Lean it out.
:+1: no question - a hesitation on snap that low is a too-rich condition.
Discussion Starter #18
Ok so I just need to readjust my map... The reason I am curious is a guy I ride with can snap his to WOT at around 30 mph and his back tire spins mine kinda hesitates and then goes so I am tryin to get where I can spin that back tire when I want to...
Discussion Starter #19
oh yeah and his is stock and his back tire spins
:dontknow: sounds to me like he just has a really hard compound rear tire
1 - 20 of 25 Posts
