1 - 4 of 4 Posts
Some times when I start off from a red light I get a Chatter @ low RPM..Kinda like you would hear when you start off in a high gear...the bike has 17k on it but I change the oil every 2k and use motul oil...any one else have the same thing happening?:dontknow:
Ride the clutch longer when taking off and make sure you changed your front sprocket with a 16 tooth.:wink:
Dirt ninja is right...this bike is geared to the moon stock (104 mph in 1st), you'll also notice it will start bogging down the engine and start pulsating below 20 mph if you don't ride the clutch...........:badteeth:
1 - 4 of 4 Posts
