Those low mount tag plates "should" work. What you're not seeing and understanding from the pic is that in some cases it will get you a ticket as it blocks the view of the plate by the tire. If you don't care about that issue, then you should understand that there isn't enough room for it. It doesn't rigidly mount there. You bolt up one end (in the case of this one, you mount it to the hugger bolts. The other end has a roller bearing on it. The rigid end is hinged. As the suspension moves up and down, the roller bearing rides on the undertail and forces the plate to move in and out of view. The hinge point is sprung so there is tension on it when the suspension extends, the plate moves back into position. Some of these designs mount to the the undertail and ride on the hugger. This one looks like it mounts to the hugger and rides on the undertail. It works. But the bearing will scratch the plastic it rides on. And may also get you pulled over for a plate violation. Do with that info as you will.
