1 - 7 of 7 Posts
I installed the boz moira on my 04 and changed the map over to the akro full map...maaaaaaaan...did I ever lose some serious low/mid range power...
how do I imporve this situation? and I noticed the akro map actually leans out the ratio at low range by as much as 20% in some cases. Isn't it supposed to do the opposite?
I'm confused
You really need to get a custom map done. A generic map just doesn't cut it for this pipe. On my map some cells are 30-40 to the lean side. I got all my low and mid range back and then some after tuning. If you do not tune properly you are going to lose low end and mid because of less backpressure. But once you tune for it you'll get it back.
Custom map man....dont buy good parts and 1/2 ass install them. If thats the case screw a tuba on it...there cheaper. Not trying to be a d!ck just trying to get my point across to ya bro. Its like buying a stering dampner and installing it with a sledge hammer....
A custom tune will get rid of that gaping hole that exhaust left.
1 - 7 of 7 Posts
