1 - 12 of 12 Posts
Hey guys I would like to see if anyone else has had this happen before. I was riding the other day through town going like 50 mph, and a loud squealing noise came from the engine on my bike for roughly 4 to 5 seconds then it stopped. It ran fine all the way home the next morning I started it up and it idled for about 5 seconds and started squealing again so I shut it off immediately. Tried starting and it is squealing while cranking..any ideas? I've already taken the starter cover off and made sure it want the starter or gears.any help will be greatly appreciated
BigCat for Prez!
post a video if u can
Won't start anymore and 1st gear is the only one that it will actually go into and when I try to roll the bike in gear the tire just slides. I just had the valves shimmed over the winter and haven't even put 100 miles on it. i'm thinking that something that he has done is the culprit
BigCat for Prez!
Man u got me then. post a video of u trying to start it. might help a little
Yes the engine is stuck but not when the clutch is pulled in the bike rolls fine. I'm going to try to post a video but the battery is dead now from trying to start it it doesn't even have enough juice to spin it any more. I know these motors are practically bomb proof and like I said it ran flawlessly before I had the valves shimmed.
Yes but it probably won't be charged until tomorrow I'll try to get a video up asap but either way the bike is going back to the guy that shimmed the valves. Its his baby no one else had been inside the motor but him
Definitely if you can, get someone to record the issue whil you replicate the sound, a member here will chime in on potential issue. Good luck to you, and hopefully the motor isn't damaged. We can assume it ain't a belt squealing. But good luck again.
Discussion Starter #11
Well guys, as expected it didn't take long to find the problem once we took the side cases off. Luckily it was a simple fix, the stator bolts backed out and found its way to the flywheel.I'll be back to riding in no time.
:thumbsup:
1 - 12 of 12 Posts
