1 - 6 of 6 Posts
Do you have any mods? It could be any number of things. Need to be more specific on symptoms but your best bet will be to take it to a shop.
I put a TRE on it then took it back off thinking it waas the problem. No i havent raced it. - 2 spocket in front
:+1: Check the connectors for where the TRE went. Also check the Cam Position Sensor wiring. Maybe its the ECM or a pinched wire somewhere. Like stated before unless you yourself are a mechanic and no what to look for take it to a shop.
1 - 6 of 6 Posts
