1 - 10 of 10 Posts
Is red on the 07 10r...Do I have to put red back in there or can I use blue like every other bike has...?
MIA Ex-Mod
I think either one will work but would prefer using the red. Just for reference, the rotor bolts are only supposed to be used once then discarded for new, I personally don't see why they can't be used more than once.
Tread
GEN II Driver
Tread
:+1:
i use the red too.
heard the same regarding one time use but have reused twice without issue.
Tread
Thanks...I will go get some red...Never heard such a thing for replacing the screws..That's :rolleyes: on their part.
Banned
I don't use either. I use a brass brush on my bench grinder, clean the threads up like new and then do the opposite. I put anti-seize on them, then using a tourqe wrench, tourqe to exact spec. I have never had any come loose and they are never a problem down the road getting them out.
Flame ON!!!
JJ
I've always used blue for all bolts on my bike, including the rotor bolts. When a manufacturer says that you have to replace certain bolts, it is usually because they are "torque to yield", meaning that they are torqued to a predetermined amount of stretch. I can understand this for head bolts or crank bearing cap bolts but not rotor bolts. I re-used mine.
Discussion Starter #8
My Gixxer has blue in all the screws. I thought red was the permanent, never to be removed, loctite....amirite?
Yes you are correct in that RED is advertised as a permanent locking agent so no i would not reuse it in this case however i would clean as JJ mentioned and use BLOO only.
Discussion Starter #10
Cool...I will brake parts clean the red off the screws and replace with blue. Thanks, fellas.!
1 - 10 of 10 Posts
